phod2
Sep 11, 2020Aspirant
RAX80 Block Services by Schedule not working
I thought the latest firmware update RAX80-V1.0.3.102_1.0.48 may have fixed this but wondering if anyone else has this issue. I have set the router to block "ALL" services (all ports from1~65535)...
Christian_R
Sep 16, 2020NETGEAR Employee Retired
Hi phod2,
Did the issue occur on previous firmware versions?
Christian
- phod2Sep 16, 2020AspirantHi Christian,
Thanks for the reply. No it’s never worked with this model.
Thanks.- Christian_RSep 17, 2020NETGEAR Employee Retired
Hi phod2,
If the feature has never worked for you, have you ever had a moment to contact our support team?
https://www.netgear.com/support/default.aspx
Christian
- phod2Sep 19, 2020Aspirant
Thanks Chris. I have previously contacted support however was pointed to "Ask the COmmunity". I have logged a new support case.
Thanks.
