SS1374
Dec 24, 2023Aspirant
Rax80 blocks vudu log in.
I am unable to access Vudu on any device on my Wi-Fi network. I get a “log in failed”. On IPads, MacBooks android tv and android cell. on my cell phone on 5g/ mobile network, it works. it is not v...
SS1374
It was.
I disabled it, rebooted the router and it is still giving the same error on all devices.
Dec 25, 2023Guru - Experienced User
Something I'd contact vudo about and see if they can help you out.
- SS1374Dec 26, 2023Aspirant
Thanks for the advice. I did. Their customer service is less than stellar.
My issue is related to the in house Wi-Fi-or my isp.
If I turn the Wi-Fi off on my phone, I can log in with my mobile data/5G network. It does accept my log in credentials. Doing the same over Wi-Fi gives the log in error.
Frustrating for sure,
All advice is greatly appreciated here.
s
- FURRYe38Dec 26, 2023Guru - Experienced User
I have a fixed wireless internet. It comes as a radio signal from our local water tower to my roof mounted radio. It is a Cambium EPMP 1000 Force 200.…..I think….
this provides a Ethernet cable that is plugged in to my Netgear Nighthawk AX8
AX6000 B-stream Wi-Fi router.
RAX80
the roof system is 8+ years old, and the router about 4. We had no issues up until this spring.
thank you for any and all inputs. It is greatly appreciated.
s
