tbraas
Nov 29, 2021Aspirant
RAX80 can only add 4 address reservations
I'm trying to get a bit of control over my network and lock down the IP addresses allocated to my IoT devices as some of them aren't robust enough to update their IP allocation after a router restart...
tbraas
The firmware version is listed in the question.
I’m using IP addresses from within the range that I have created for my 255.255.255.0 network. The UI will only allow me to enter 4 address reservations.
Nov 30, 2021Guru - Experienced User
What is the range of yoru default IP address pool? .2 to 254?
What happens if you change the IP address pool to .100 to .200?
What browser are you using? Happens with MS Edge or Firefox?
