D-hauser
Aug 26, 2019Aspirant
RAX80 cannot connect to modem
So my internet went down today and it seems that my RAX80 can't connect to my modem. When I directly plug my computer to my modem it works fine but once I put in my router nothing works. I tried reset...
michaelkenward
Aug 27, 2019Guru - Experienced User
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
D-hauser
Aug 27, 2019Aspirant
I have that a shot and nothing works, I cant even connect to the wifi. Would performing a factory reset possibly fix my problem?
- michaelkenwardAug 27, 2019Guru - Experienced User
Who knows? In desperate circumstances, it is always worth a go.
- D-hauserAug 27, 2019AspirantFactory resetting didn't seem to work. Is there anything else you think might help resolve my situation?
