tkillian
Oct 08, 2020Aspirant
RAX80 can't login
Just got this refurbed. Working just fine to connect devices to, but now I can't login via ip address, routerlogin.com, or the Nighthawk app.
- tkillianAspirant
To clarify, routerlogin.com gives me this page: https://www.netgear.com/home/products/networking/routerlogincom.html
192.168.1.1 gives me "the connection was reset"
Nighthawk app says "issues connecting with (my network).
- Christian_RNETGEAR Employee Retired
Hi tkillian,
May you perform a factory reset by holding down on the reset button for 15+ seconds and run through the setup assistant again.
Christian
- hmahaAspirant
I have the same issue. Unable to access the router using 192.168.1.1 Seems more than one person is having a problem. Tried on idfferent computers but with same result. Netgear should investigate the issue. I had no problem with router logon 3 months back but today I am having the problem. It does not bring up initial page for logon as if the router is just not responding. I have rebooted the router but no help. I am also not able to bring up the application on my iphone. It indicates that " Issue conneting with XXXX name of the wifi" while detectng Product. With iphone I am able to use the wifi e.g browse website while only wifi enabled.
