Kpoe2000
May 17, 2023Aspirant
RAX80 Connection to Fiber
Good afternoon and thank you for stopping by! I just recently switched from cable to fiber internet. My RAX80 — Nighthawk AX8 is the same router used for both connections. The internet was oper...
michaelkenward
May 17, 2023Guru - Experienced User
Kpoe2000 wrote:
My RAX80 — Nighthawk AX8 is the same router used for both connections. The internet was operational when using the cable internet provider.
I see no mention in this conversation of a "reset" of your RAX80.
You need to get it to forget any settings it inherited from your cable network.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Maybe you did this, but, as I say, I can't see any mention of this. It is the first thing to do whenever you change the Internet service, before all of the other recommended sensible measures.
An alternative is to use the browser graphical user interface (GUI) to go into the router and take it through its Internet Setup Wizard.
Kpoe2000
Correct sir, I have only "rebooted" it through the phone app and did a manual power cycle.
I plan on going home and logging in with the admin / pw info. I'm assuming the internet setup wizard is somewhere inside that GUI after logging in?
- michaelkenwardMay 17, 2023Guru - Experienced User
Aha. That could be the issue.
- Advanced
- Advanced Home
- Setup Wizard
Netgear has steadily improved this over the years. The wizard plays nicely with most ISPs, although it can get confused by exotic networks.
One more thought, if this fails, perhaps because the admin password doesn't work, then the reset puts you back to the original settings and default password.
- Kpoe2000May 17, 2023AspirantI attempted to use the setup wizard but got the error “no Ethernet cable connected.” I changed the cord (even though I had previously confirmed the cable that was connected worked).
Still could not use the wizard by browser GUI. I used the manual reset on the back of the router.
It will get connection for a minute or so and then lose it again, repeating this cycle indefinitely.- FURRYe38May 17, 2023Guru - Experienced User
You can select setup the router manually...
Possible this router is faulty. Would be good if you could test it at a different location if possible and see.
