Kpoe2000
May 17, 2023Aspirant
RAX80 Connection to Fiber
Good afternoon and thank you for stopping by! I just recently switched from cable to fiber internet. My RAX80 — Nighthawk AX8 is the same router used for both connections. The internet was oper...
Kpoe2000
Correct sir, I have only "rebooted" it through the phone app and did a manual power cycle.
I plan on going home and logging in with the admin / pw info. I'm assuming the internet setup wizard is somewhere inside that GUI after logging in?
michaelkenward
May 17, 2023Guru - Experienced User
Aha. That could be the issue.
- Advanced
- Advanced Home
- Setup Wizard
Netgear has steadily improved this over the years. The wizard plays nicely with most ISPs, although it can get confused by exotic networks.
