Kpoe2000
May 17, 2023Aspirant
RAX80 Connection to Fiber
Good afternoon and thank you for stopping by! I just recently switched from cable to fiber internet. My RAX80 — Nighthawk AX8 is the same router used for both connections. The internet was oper...
Kpoe2000
I would agree the router could be faulty and I will check that for sure. However, it was working just seconds before shutting it down and connecting it to the new ONT.
May 17, 2023Guru - Experienced User
If you can test it at a different location, would be telling. Anything could have happened in between last connection and new connection with ONT.
We still know know what the brand and model # is of this ONT that was installed.
- Kpoe2000May 17, 2023Aspirant
- We still dont know what the brand and model # is of this ONT that was installed.
- ONT appears to be an ADTRAN SDX622v
I am currently connected by cat6 directly to my computer and getting internet immediately upon connection with no interruptions.
If I do have to buy a new router (it seems more likely now), do you have a suggestion for multi gig speeds? Residential use, 30+ individually connecting wifi devices, gaming computers, mulitple 4k streaming tv's.
- FURRYe38May 17, 2023Guru - Experienced User
How big is the home?
RAX120 and 200 and RAX300 and 500 have multi gig WAN ports.
If you want something MESH, Orbi 8 and 9 series have multi gig WAN ports, 9 series has 2.5Gb LAN port.
Gaming, XR1000 comes to mind.
