yashago
Aug 24, 2020Guide
RAX80 date and time issues
My RAX80 runs on firmware v1.0.3.98_1.0.46. Router status shows time from 14 days ago. reloading page shows the same time plus few seconds but minutes never advance. NAT was configured to use defau...
- Aug 25, 2020
yashago wrote:My RAX80 runs on firmware v1.0.3.98_1.0.46.
NAT was configured to use default NETGEAR time servers, I changed that to use time.google.com and rebooted router.
Correct day and time appeared upon reboot but then the minues would not advance again.
Any suggestions?I sent a private message to @Christian_R with my serial number & email address. I was sent the beta firmware which has solved the NTP Router Time Issue and ipV6 connectivity.
SAM_the_GAM
Aug 25, 2020Luminary
Any suggestions?
yashago
Aug 25, 2020Guide
Thank you SAM_the_GAM, I will follow your suggestion and update.
- yashagoAug 25, 2020Guide
SAM_the_GAM thanks for your advice. I received a beta firmware and it seems that some time issues are resolved and some aren't.
Logs show correct time now.Thanks!
