pjmulvaney
Apr 14, 2020Aspirant
RAX80 device type pick list is blank
RAX 80 Firmware 1.0.1.70_1.0.30 In summary I have close to 30 devices connected, and I want to begin my QoS setup to prioritize some traffic such as my XBOX which tends to lag and disconnect. Ques...
Christian_R
Apr 16, 2020NETGEAR Employee Retired
Hi pjmulvaney,
If you don't mind, would you provide a screenshot of what you see.
Thanks,
Christian
JeffMills
Apr 26, 2020Aspirant
I have the same issue. Nothing shows up in the Device Type drop down.
Attached is a screen shot that doesn't show much because there isn't much to show.
I have clicked on the Device Type dropdown and that is what it looks like.
- Christian_RApr 29, 2020NETGEAR Employee Retired
Hi JeffMills,
May you let us know what firmware version your router is on.
Thanks,Christian
- JeffMillsApr 30, 2020Aspirant
Firmware version V1.0.1.70_1.0.30
- pjmulvaneyApr 30, 2020AspirantWhat is that drop down field used for specifically. I read some other posts saying that java is required to display the fields but that didn’t work for me either.
