Chris11271984
Jul 06, 2019Guide
RAX80 Disconnecting Hardwired connection only
On FW 1.0.1.58 Just randomly a few times a day anything hardwired to the rax80 will disconnected and then immediately reconnect. Everything connected via wifi stays connected without any interruption...
SAM_the_GAM
Jul 06, 2019Luminary
The problem you are describing is currently a bug in 1.0.1.58 firmware. Downgrade to 1.0.1.56 or 1.0.1.40 and the problem goes away. I encountered the same disconnection issue with 1.0.1.58.
- Chris11271984Jul 06, 2019GuideI've downgraded to 1.0.1.40 hopefully no other issues will come up
