wolffpower
Jan 21, 2021Aspirant
RAX80 drops connection at same time every day
I've purchased an RAX80 a few months ago. I've recently noticed that the router drops the internet connection at almost exactly the same time every day: at around 3:31am local time (AEST, Australia)....
wolffpower
I did come across this similar post but it does not have a solution either: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/rax80-wifi-drop-once-per-day/m-p/1966199#M12104
Christian_R
Jan 26, 2021NETGEAR Employee Retired
Hello wolffpower,
May you try reverting to the previous firmware version linked below and let us know how it turns out.
https://kb.netgear.com/000062282/RAX80-Firmware-Version-1-0-3-102
Christian
- wolffpowerJan 26, 2021Aspirant
Thanks for the suggestion Christian_R . I've downgraded to the firmware version you suggest and will monitor progress. I'll post back here either way.
- Christian_RJan 26, 2021NETGEAR Employee Retired
Hi wolffpower,
Sounds good. Looking forward to your next update!
Christian
- wolffpowerJan 28, 2021Aspirant
Hi Christian_R . Unfortuantely this doesn't seem to have worked. The router dropped the internet signal again this morning, and again at exactly 3:31am local time. Power cycling the router (on/off) restored the connection as usual.
It didn't drop the signal yesterday morning for some reason, which gave me false hope that the downgrade of firmware had worked.
Any other suggestions?
