Brushtail
May 03, 2019Aspirant
RAX80 Ethernet has no Internet Access
I have just setup the RAX80 I have just purchased as a replacement for my Dlink Dir-890L router. Wifi access seems to work fine and provides internet access, but if I switch to ethernet mode on my pc...
additude
May 04, 2019Virtuoso
Why do you feel that that it's a router related issue?
Is it because it worked before you installed the new AX, but doesn't work now?
It sounds to me as though you have a cabling problem between the router and the pc or that you have an ethernet adapter problem in the "pc"...
Maybe you need to update the drivers for the Adapter on your PC.
Check that another device can be cabled to the router and be recognized by the router and reach the internet.
Check in the router that it registers an attached device via cable.
Check the speed 10/100/1000 that you are connected at via the cable.
Make sure in the router that you do not have anything disabled via parent controlls, schedules, etc.
Start with those things.
