Brushtail
May 03, 2019Aspirant
RAX80 Ethernet has no Internet Access
I have just setup the RAX80 I have just purchased as a replacement for my Dlink Dir-890L router. Wifi access seems to work fine and provides internet access, but if I switch to ethernet mode on my pc...
schumaku
May 04, 2019Guru - Experienced User
Brushtail wrote:
Looking through all the options I also do not see any reference to 160MHz channels, have they been removed?
Different from earlier Netgear routers, there is no dedicated HT160 mode control in the RAX80. If you have wireless clients supporting 160 MHz (eight 20 MHz channels), just put the WiFi Mode selector to [Up to 4800 Mbps].
