Brushtail
May 03, 2019Aspirant
RAX80 Ethernet has no Internet Access
I have just setup the RAX80 I have just purchased as a replacement for my Dlink Dir-890L router. Wifi access seems to work fine and provides internet access, but if I switch to ethernet mode on my pc...
Christian_R
May 07, 2019NETGEAR Employee Retired
Hello Brushtail,
Would like to hear if you were able to perform the recommendations additude and michaelkenward provided.
~Christian
Brushtail
May 09, 2019Aspirant
Thankyou to everyone for the responses. I've just checked the connection options here and installing the new rounter and setting up the wifi interface has caused the windows network to connect on a pulic network even though the setup with the previous router was private. Also the ethernet interface is now connecting to the internet. It took over 2 hours from router installation and connecting windows 10 to the routers wifi interface for the ethernet interface to actually start working. It seems from my experience that the recommendations to connect to the router with ethernet in order to setup the router is not workable with the router I have out of the box.
