massam4
Oct 07, 2019Aspirant
RAX80 Fan
Is there anyone that can tell me when the fan off the RAX80 turns on. I have it for 2 weeks now and it only ever has turned when I reseted it and even then it only does that for 5 sec. The router g...
Oct 08, 2019Guru - Experienced User
Yes it is. I don't know the specifics at that temp the fan turns on but I've only managed to get my RAX200 to turn the fan on (other than bootup) once and I was stressing it with multiple transfers to really see if I could max it out. In everyday use, I haven't heard it run a single time. It does get warm but not hot.
