Fespinosa
Jul 11, 2020Tutor
RAX80 firmware 1.0.3.88_1.0.41 issues???
anyone experiencing issues with the new firmware 1.0.3.88_1.0.41 causing your router to stop working? i just received a new replacement (the 2nd one in the past month). ive had this model for a year ...
Christian_R
Jul 13, 2020NETGEAR Employee Retired
Hi Fespinosa,
Has support been able to follow up on your issue after receiving the replacement router?
Christian
- FespinosaJul 13, 2020TutorNo.
- FespinosaJul 17, 2020TutorThank you but I don't think you are going to be able to assist. Netgear told me that because I had the router for little bit more than a year they can't replace my router. But I got an update on this matter. This morning the router is having the same issue again! I honestly don't know what this could be. I have another netgear router r7000 that I use when the RAX80 doesnt work and have no problems with it. I connected the RAX80 to different power outlets around my house and didn't resolve the issue. As I stated previously I left the older firmware version and I'm pretty sure I set the options to not update automatically. I need to get the router to a working state to make sure that it didn't update the firmware or if it still has the same.
