Fespinosa
Jul 11, 2020Tutor
RAX80 firmware 1.0.3.88_1.0.41 issues???
anyone experiencing issues with the new firmware 1.0.3.88_1.0.41 causing your router to stop working? i just received a new replacement (the 2nd one in the past month). ive had this model for a year ...
Christian_R
Jul 16, 2020NETGEAR Employee Retired
Fespinosa,
I can assist with support following up on your case. If you're interested, send me a private message with your email address and case number(s).
Christian
Fespinosa
Jul 18, 2020Tutor
Christian_Rupdate. I was able to get the router back to a working state and was able to log in and found out that it had the new firmware installed (i thought i had disabled the automatic update). I downgraded to V.1.0.2 firmware and disabled the automatic update option. Can you please check if there are any bugs on this new firmware? I hope this is the reason for my issues but need you guys to be aware of this. I will send you a private message as well but wanted other people to be aware of this and hopefully they can confirm that this firware has some serious bug. thanks. i will update the post if the issue occurs with this older firmware.
- afh3Jul 26, 2020Tutor
Yep.
I have two RAX80 units configured as wireless access points. After updating them to RAX80-V1.0.3.88_1.0.41, all four of the Samsung S20 Ultra phones in the house will no longer connect to the access-points. "Error getting IP address".
Downgraded them to V1.0.2.76_1.0.35 and they work perfectly (phones will connect with no problems) - albeit with significant security risks due to the old firmware.
In summary:
- Factory reset both RAX80 units and reconfigured them as WAP mode with the V1.0.3.88_1.0.41 production firmware. Same issue.
- Factory reset both RAX80 units and reconfigured them as WAP mode with the V1.0.3.92_1.0.43 hotfix firmware. Same issue.
- Factory reset both RAX80 units and reconfigured them as WAP mode with the V1.0.2.76_1.0.35 old firmware. Works perfectly with all four phones.
- Factory reset two older R8000 units and reconfigured them as WAP mode with the V1.0.4.56_10.1.71 hotfix firmware. Works perfectly with all four phones.
- Factory reset two older R8500 units and reconfigured them as WAP mode with the V1.0.2.132_1.0.99 hotfix firmware. Works perfectly with all four phones.
I'm thinking I may be seeing a trend here.
The RAX80 units are staying out of service until such time that firmware can be released that works like V1.0.2.76_1.0.35 does - only with the most current security fixes in place.
Oh, am I bitter about $1000 worth of non-working RAX80s? Yeah.
But hey, at least it has only taken dozens of hours of my time to discover and get back to a working configuration with R8500s.
- FespinosaJul 27, 2020TutorMy RAX80 has been working with no issues since 7/18/20, the day that I downgraded the firmware. Just like you, I see a pattern here. I'm glad I dont have a hardware problem because this thing isn't cheap, but I'm also not happy to be running an older firmware with security holes so Netgear needs to address this issue.
- wildncrazyguyAug 13, 2020Guide
Not sure what they have broken with the .3 firmware, but i've tried all the .3 firmwares as they come out and all do the same thing. Internet connectivity is crap. I revert to the RAX80-V1.0.2.76_1.0.35 and works just fine again.
I wish we had a way to get netgear support to look at this junk. I would pay for support if it weren't a problem with their firmware!!!
- FespinosaAug 13, 2020TutorI haven't had a problem since i downgrade the firmware. But I'm definitely not happy running an older firmware
