Yaksmusag
Sep 25, 2020Aspirant
RAX80 firmware update failed due to GUI update failure
Any help? I tried through the browser and app with no success to update the firmware on my RAX80 WiFi router. It keeps saying GUI update failed and doesn’t update. Anyone know how to fix?
Sort By
Which firmware are you updating to?
Are you hardwired into the router?
Did you extract the firmware prior to trying to install it?
What firmware version are you on?
- YaksmusagAspirant
Try following the manual update process.
The manual walks you through it on page 99
