billdavies
Jul 31, 2022Star
RAX80 firmware update failed due to GUI update
I seem to be having some version of this issue. I am hard-wired to a 10/100/1000 switch and getting to the router that way. It is not easily accessible to where I sit. No issues getting to it, eit...
- Aug 09, 2022
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 31, 2022Guru - Experienced User
Perform a manual FW update using a wired PC and web browser by downloading the FW file as outlined here:
I would then factory reset the router and setup from scratch with out a prior backup configuration after the FW has been applied.
- billdaviesJul 31, 2022Star
Makes me long for the days when Apple laptops had ethernet ports. 😕
- FURRYe38Jul 31, 2022Guru - Experienced User
Just add a USB to Ethernet adapter to the mac book. I use them on mine.
