billdavies
Jul 31, 2022Star
RAX80 firmware update failed due to GUI update
I seem to be having some version of this issue. I am hard-wired to a 10/100/1000 switch and getting to the router that way. It is not easily accessible to where I sit. No issues getting to it, eit...
- Aug 09, 2022
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Aug 03, 2022Guru
So it updated successfully then?
billdavies
Aug 08, 2022Star
Yes, just as it has done for 3-4 years, it updated fine when I went to admin panel. No need to crawl in my basement with a laptop. I don't know what was done, but I assume something was done on the server side.
- FURRYe38Aug 09, 2022Guru
Enjoy. 📡
