Ahutch08
Jan 05, 2022Tutor
RAX80 Firmware V1.0.5.132 unable to connect 1TB USB SSD
I just installed RAX80 router got all devices connected and went to add a 1Tb LaCie Rugged SSD to the router via the USB port. When I connect the SSD to the USB, the USB 3.0 light never lights up (ev...
nielsvds
Jan 09, 2022Luminary
With larger size external SSD or HDD, you should opt for these that come with a seperate powersupply to get detected by the router. The other blocking factor is that the firmware only accept a certain limit of disk space.
Ahutch08
Jan 09, 2022Tutor
Ended up returning SDD and going with one of the hard drives on the “tested and verified” list above.
- michaelkenwardJan 10, 2022Guru - Experienced User
Ahutch08 wrote:
Ended up returning SDD and going with one of the hard drives on the “tested and verified” list above.Hope it works.
