TheComputerHyp
Jul 09, 2022Guide
RAX80 Firmware V1.0.6.138_1.0.76 = No internet
Same exact issue here. Have done multiple FW upgrades in the past that DID NOT require a factory reset (good coding). There is obviously something wrong with this FW update (bad coding). Netgear shou...
- Jul 14, 2022
I would manually load the FW file on the router using MS Edge or Firefox on a wired PC.
After the router has processed the FW file and reboots and comes back to ready, power OFF the Router and ISP modem for 1 minute.
Than back ON with the modem first, then power ON the router.
After it comes to ready, with a wired PC, log into the routers web page and navigate to Advanced Tab/Admin/Backup and select ERASE.
Walk thru the setup wizard and complete it.
Check internet access with wired and wireless devices.
TheComputerHyp
Jul 13, 2022Guide
I tried your suggestion. Installed FW V1.0.6.138_1.0.76 and did a factory reset.
The issue persists. No internet access after wasting time doing this.
Although I did notice that when I ran a speed test from within the QoS menu, that the router was connected with wonderful speed. But none of my network devices were able to connect to the internet.
Once again, I rolled back the FW to V1.0.5.132_1.0.69 to get my devices connected to the internet.
I pity the poor tech-challenged soul whose router automatically updated to the latest FW,
Jul 13, 2022Guru - Experienced User
Do you happen to power OFF the router after applying the FW for 1 minute them back ON then factory reset?
- TheComputerHypJul 13, 2022Guide
No, I did not power off. You failed to mention that step.
OK, I'll try once more, ONLY IF you give me an EXACT DETAILED sequence of events.
- FURRYe38Jul 14, 2022Guru - Experienced User
- TheComputerHypJul 14, 2022Guide
Followed your instructions and learned what the problem was.
After following your instructions, internet access was available to all devices. BUT, as soon as I loaded my saved backup CFG file, I lost ALL internet access. Final solution was to install the FW update but NOT reinstall my saved configuration file. I don't understand why this was a problem. After I rolled back the FW update the other day, I did restore the backed up CFG file and everything worked well. For whatever reason, my backup CFG file was the culprit. The new FW didn't like my backup CFG file, but the old FW did. Go figure.
Thanks for all the assistance.
