TheComputerHyp
Jul 09, 2022Guide
RAX80 Firmware V1.0.6.138_1.0.76 = No internet
Same exact issue here. Have done multiple FW upgrades in the past that DID NOT require a factory reset (good coding). There is obviously something wrong with this FW update (bad coding). Netgear shou...
- Jul 14, 2022
I would manually load the FW file on the router using MS Edge or Firefox on a wired PC.
After the router has processed the FW file and reboots and comes back to ready, power OFF the Router and ISP modem for 1 minute.
Than back ON with the modem first, then power ON the router.
After it comes to ready, with a wired PC, log into the routers web page and navigate to Advanced Tab/Admin/Backup and select ERASE.
Walk thru the setup wizard and complete it.
Check internet access with wired and wireless devices.
Jul 14, 2022Guru - Experienced User
TheComputerHyp
Jul 14, 2022Guide
Followed your instructions and learned what the problem was.
After following your instructions, internet access was available to all devices. BUT, as soon as I loaded my saved backup CFG file, I lost ALL internet access. Final solution was to install the FW update but NOT reinstall my saved configuration file. I don't understand why this was a problem. After I rolled back the FW update the other day, I did restore the backed up CFG file and everything worked well. For whatever reason, my backup CFG file was the culprit. The new FW didn't like my backup CFG file, but the old FW did. Go figure.
Thanks for all the assistance.
- FURRYe38Jul 16, 2022Guru - Experienced User
OK thanks for letting us know. Yes, as FW is developed and graduated, Some, I say "some" features in and out of the backup configuration, IF made on older versions of FW, maybe come incompatible with newer versions of FW. Why we recommend factory resets and setup from scratch, IF problems are encountered or if problems are encountered with using older conffiguration backup files. Setup from scratch, now make a new back up configuration to file on this version of FW. Should be good to go now here.
Enjoy.
