schumaku
Oct 22, 2019Guru - Experienced User
RAX80 Firmware Version 1.0.1.64 -Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz
RAX80 Firmware Version 1.0.1.64 says: Bug Fixes: ... Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto. Uh waht - this does not make any sense to m...
I'd have to agree. I usually recommend 1-6-11 for people with 2.4ghz congestion problems.
GabboCH
Oct 27, 2019Apprentice
My router is on the latest firmware (64) and can confirm that the router still selects channel 1 when set in auto mode.
Incidentally, when channel 1 is active, nothing can connect to the 2.4ghz channel.
Is it a bug in the release notes or a bug in the router they were trying to prevent with this change?
Either way, channel 1 is still used in auto mode.
