schumaku
Oct 22, 2019Guru - Experienced User
RAX80 Firmware Version 1.0.1.64 -Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz
RAX80 Firmware Version 1.0.1.64 says: Bug Fixes: ... Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto. Uh waht - this does not make any sense to m...
GabboCH
Oct 30, 2019Apprentice
Christian_RDo you have some news about this?
Christian_R
Nov 04, 2019NETGEAR Employee Retired
Hello Everyone,
The following 2.4GHz channels will no longer be used when set to auto. However, you will still have the option to select channels 1,6, and 11 but will need to be done manually.
Christian
- schumakuNov 04, 2019Guru - Experienced User
Christian_R what is the idea behind this (strange) design change?
Does the same apply to EU versions for the channels 1, 7, and 13 then?
Why should the the channels 11, 12, and 13 (as per the release notes) be masked? Sorry, this makes zero sense to me. And the incomplete and changing information coming frok Netgear is concerning at.least. Christian_R
- GabboCHNov 04, 2019Apprentice1st question is why?
2nd question, I have this firmware & my router selected channel 1 in auto mode (there's a screenshot in the other thread).
