schumaku
Oct 22, 2019Guru - Experienced User
RAX80 Firmware Version 1.0.1.64 -Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz
RAX80 Firmware Version 1.0.1.64 says: Bug Fixes: ... Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto. Uh waht - this does not make any sense to m...
Christian_R
Nov 04, 2019NETGEAR Employee Retired
Hello Everyone,
The following 2.4GHz channels will no longer be used when set to auto. However, you will still have the option to select channels 1,6, and 11 but will need to be done manually.
Christian
schumaku
Nov 04, 2019Guru - Experienced User
Christian_R what is the idea behind this (strange) design change?
Does the same apply to EU versions for the channels 1, 7, and 13 then?
