Tybolt
Sep 14, 2020Initiate
RAX80 firmware version 1.0.3.102 - VLAN ID changed on Internet port
I just upgraded my RAX80 firmware to version 1.0.3.102_1.0.48 and lost Internet access. After some troubleshooting I decided to factory reset the router and set it up again. When I went into the VLAN...
schumaku
Sep 14, 2020Guru - Experienced User
No idea why the configured WAN side VLAN for the Internet access should have gone bullocks. The default for the Internet VLAN was and is always 10 on the Netgear routers.
Tybolt wrote:When I bought the router 6 months ago I had to manually add the VLAN ID rule on in the Internet port from scratch. My ISP (Internode in Australia) requires a VLAN tag (VLAN ID 2 on the Internet port) to connect. I had to edit the default rule to restore Internet access.
Part of the manual config - AFAIK there is no Internet connection assistent to set-up the Internet VLAN (and others) in an automatic way.
Tybolt wrote:The release notes mention a change, "Fixes the issue where port 1 and port 5 can’t be added to the VLAN bridge group". This might be related.
The VLAN bridge group is to forward a non-Internet (typically IPTV or VoIP VLANs) to a specific port - this was not possible to configure to LAN port 1 and LAN port 5 before. Just for Internet, you don't need this. Well possible, they messed up something in this context 8-/
