The-Ark
Dec 20, 2020Guide
RAX80 Firmware Version 1.0.3.102 & 1.0.3.106 Bug (Link aggregation & QoS)
I encounter problem with RAX80 Firmware Version 1.0.3.102 & 1.0.3.106 The Link aggregation (IEEE-802.3ad) function will not work if I enable the QoS. Once I enable the QoS fiunction, Link aggrega...
Christian_R
Dec 24, 2020NETGEAR Employee Retired
Hello The-Ark,
May you revert back to FW v1.0.3.102 and let me know if your issue persists.
Christian
Mythic82
Dec 31, 2020Aspirant
I have had the same problem since 1.0.3 still on 1.0.2
I tried to disable the linkaggregation but qos was stil broken
Did factory reset before and after update but still same problem.
Also the UI is slowing down to a crawl after a while so i dont dare to update anymore until there is no bugs left in 1.0.3
