Nmouneimne
Sep 07, 2020Apprentice
RAX80 Firmware Version 1.0.3.102 seems to have a time zone bug.
I installed 1.0.3.102 and the time zone setting would not stick. Stuck at central. Had to rollback to .88 for things to work. With the pandemic and my whole family working and learning from home, I ...
Nmouneimne
Sep 11, 2020Apprentice
I did not. Has someone verified that the Router needs a factory reset after this firmware update? If you know that a factory reset is required, I will reload the new bios and try. Otherwise, I will just let the beta testers handle. Also, I do not recall seeing instructions indicating a factory reset was required or recommended after this update.
jcax
Sep 12, 2020Star
I agree both factory resets and reconfigurations from scratch are a pain, and I'm not defending the quality of releases or beta-level firmware being released.
That said, doing a factory reset while on (beta) build 99 and then allowing the initialization routine to upgrade the device to build 102 did clear-up an issue for me. Note that I DID NOT restore settings from a backup to the 102 firmware, I reconfigured from scratch.
I think that path I took is essentially the net same as upgrading to 102 and then doing a factory reset.
Just food for thought.
