daweidu
Jul 31, 2020Star
RAX80 Firmware Version 1.0.3.98
Now I can't login my router any more. It said wrong password.
daweidu
Jul 31, 2020Star
nope. my port forwarding is working. This version might fix my obi problem.
Jul 31, 2020Guru - Experienced User
Have you tried the password recovery option?
- daweiduJul 31, 2020Star
404 Not Found
The resource you have requested is not available.
Do you have a rax80 to test?
so you need to enable password recovery feature before?
my question is why they break the password in the first place.
Improves the CE-DFS behavior.
now it is crazy enough just show part of http://192.168.1.1/start.htm
crazy netgear qa. I really do not believe they do any testing.
