onurich01
Sep 30, 2020Tutor
RAX80 Firmware Version V1.0.3.102_1.0.48 Is assigning duplicate IPs to devices on my network
I just installed the latest firmware for the RAX80. It blanked my password and I had to perform a factory reset of the router. The router is assigning duplicate IP addresses to devices on my network ...
onurich01
Oct 05, 2020Tutor
Christian,
V1.0.3.102_1.0.48 is the latest firmware. My issue is that I believe this latest firmware which was intended to allow the attached device list to better hold onto it's naming, has actually broken it by holding on to names, and then assigning the same IP to two different devices.
Rivhard
Christian_R
Oct 09, 2020NETGEAR Employee Retired
Hi onurich01,
Thanks for confirming. I'd like for our support team to reach out to you for further investigation. If you wish to be contacted, may you send me a private message with your email address and phone number.
Thanks,
Christian
