bdschwar
Sep 07, 2020Guide
RAX80 FW-Update 1.0.3.102 caused complete reset of router and outage
Dears, I'm really upset: Having had issues with the buggy 1.0.3.98 version I updated today to the most recent version (1.0.3.102 by 4th September), and this rubbish completely resetted my router w...
Christian_R
Sep 11, 2020NETGEAR Employee Retired
Hi Bernd,
Thanks for sharing your feedback. May you try updating to the latest firmware version manually using a wired device. Please let me know if your issue persists.
Christian
bdschwar
Sep 22, 2020Guide
Dear Christian,
I never flash a device differently than connected wiredly and as FW-update-assisstant did not work, there was no choice than to try it manually. So the issue still exists and why should I have a new try with the same version as it's still the latest one?
My provider clearly stated no issues on his side, the router could/did not connect after applying the patch, so what do you want me to tell?
I will not apply this rubbish again...
Regards
Bernd
