mysterioustrngr
Mar 06, 2022Aspirant
Rax80 gets low bandwidth behind ATT BG210
Good Afternoon, I have a perplexing low bandwidth on wifi issue that doesn't seem to be solved by putting the ATT router in ip passthrough mode. I discovered I get the max download of 600 mbps bu...
Mar 06, 2022Guru - Experienced User
What devices are you speed testing with? Wired is preferred.
What speeds are you getting at the ISP modem/router with a ethernet connected PC/laptop?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
mysterioustrngr
Mar 08, 2022Aspirant
Hi FURRYe38,
Thanks a lot for your help.
"What devices are you speed testing with? Wired is preferred."
Wired speed is full as expected from the rax80 behind the ATT BG210 which is about 600 Mbps up/down. It's the wireless from rax80 that's the problem.
"What Firmware version is currently loaded?"
latest available for rax80 - Firmware Version V1.0.5.132_1.0.69
"What speeds are you getting at the ISP modem/router with a ethernet connected PC/laptop? "
600 up/down
"This would be a double NAT condition which isn't recommended."
For the ATT BG210, the recommendations I saw were to put it in ip passthrough as the only option and turn off the firewall features, which I did. My public IP was passed through to the RAX80 but it didn't make any diffierence in speed over wireless. I also tried to disable all fhe features I could like AX mode and smart connect but it lowered speeds to about 70 mpbs
FURRYe38 wrote:What devices are you speed testing with? Wired is preferred.
Couple of options,
- FURRYe38Mar 09, 2022Guru - Experienced User
What WiFi devices are you speed testing with?
How do you have the wifi settings configured on the router?- mysterioustrngrMar 09, 2022Aspirant
Thanks again! I still would've thought that putting the ATT router in passhthrough for rax80 to get direct public IP and not have to route from 10.x network to 19.168 gateway and then NAT out to public would help but it doesn't. AP mode on the rax80 works great but I lose the few useful features thast it has.
FURRYe38 wrote:What WiFi devices are you speed testing with?
Mac laptop and samsung phone since they have capability to test well as long as I'm close enough to router for 5ghz .
How do you have the wifi settings configured on the router?Enabled:
AXOFDMA in 2.4 and 5ghz
Smart Connect
2.4ghz
enable 20/40 mhz co-existence
channel auto
mode up to 1200 Mbps
transmit 100%
5ghz
mode up to 4800 Mbps
transmit 100%
- FURRYe38Mar 10, 2022Guru - Experienced User
Is the wifi radios disabled on the ISP modem?
