mysterioustrngr
Mar 06, 2022Aspirant
Rax80 gets low bandwidth behind ATT BG210
Good Afternoon, I have a perplexing low bandwidth on wifi issue that doesn't seem to be solved by putting the ATT router in ip passthrough mode. I discovered I get the max download of 600 mbps bu...
mysterioustrngr
Mar 09, 2022Aspirant
Thanks again! I still would've thought that putting the ATT router in passhthrough for rax80 to get direct public IP and not have to route from 10.x network to 19.168 gateway and then NAT out to public would help but it doesn't. AP mode on the rax80 works great but I lose the few useful features thast it has.
FURRYe38 wrote:What WiFi devices are you speed testing with?
Mac laptop and samsung phone since they have capability to test well as long as I'm close enough to router for 5ghz .
How do you have the wifi settings configured on the router?
Enabled:
AXOFDMA in 2.4 and 5ghz
Smart Connect
2.4ghz
enable 20/40 mhz co-existence
channel auto
mode up to 1200 Mbps
transmit 100%
5ghz
mode up to 4800 Mbps
transmit 100%
Mar 10, 2022Guru - Experienced User
Is the wifi radios disabled on the ISP modem?
- mysterioustrngrMar 10, 2022Aspirant
Hi Furrye38,
mac laptop and samsung phone that are getting 600 up/down (max) but rax80 in AP mode
Yes
