vietp13
Nov 02, 2019Aspirant
RAX80 Half Speed
After a firmware update or a router rebooty wired speed goes from 940mbps to 450. I would have to reset the router and configure the setting as I did before to get my speed back to normal. This happen...
ChAKiBrOs
Nov 15, 2019Guide
I'm having same problem here, it seems speed capped after time sync with NTP sever.
- staindwithinkNov 15, 2019Aspirant
Rax80 Mine does the same thing daily...reset the modem every day so annoying 1 gig down to 500 reset and get my gig back
