vietp13
Nov 02, 2019Aspirant
RAX80 Half Speed
After a firmware update or a router rebooty wired speed goes from 940mbps to 450. I would have to reset the router and configure the setting as I did before to get my speed back to normal. This happen...
ChAKiBrOs
Nov 15, 2019Guide
I'm having same problem here, it seems speed capped after time sync with NTP sever.
staindwithink
Nov 15, 2019Aspirant
Rax80 Mine does the same thing daily...reset the modem every day so annoying 1 gig down to 500 reset and get my gig back
