vietp13
Nov 02, 2019Aspirant
RAX80 Half Speed
After a firmware update or a router rebooty wired speed goes from 940mbps to 450. I would have to reset the router and configure the setting as I did before to get my speed back to normal. This happen...
Christian_R
Nov 15, 2019NETGEAR Employee Retired
Hello Everyone,
Would you mind providing me with the firmware version your RAX80 is currently on? We recommend ensuring your device is on the latest firmware.
Christian
vietp13
Nov 15, 2019Aspirant
The firmware I'm using is v1.0.1.64_1.0.27
- ChAKiBrOsNov 16, 2019Guide
I have tried different version of firmware, speed can be resumed after factory reset or enable QOS, but it capped after time sync.
- Christian_RNov 19, 2019NETGEAR Employee Retired
Hello Everyone,
Thanks for confirming. For those who have not reverted to a previous firmware version, I'm curious to know the outcome once you're able to.Thanks,
Christian
