jcax
Jul 14, 2020Star
RAX80 has no fan?
I'm on my second RAX80. There is no fan inside that I can see. The first one I purchased used thru Amazon, and a week or so later I found a new one on sale by Amazon for a little less that the price...
- Jul 16, 2020
Hi jcax,
All RAX80s are built with a fan. If you believe your device doesn't have a fan, I would suggest contacting our support team.
https://www.netgear.com/support/default.aspx
Christian
Christian_R
Jul 16, 2020NETGEAR Employee Retired
Hi jcax,
Christian
jcax
Jul 16, 2020Star
Thanks. Done. I appreciate the response.
