brooklyngyal
Nov 19, 2020Aspirant
RAX80 How to "Disable" Privacy Separator
I have a Netgear/Nighthawk/RAX80 router. I need to "Disable" the Privacy Separator but am unable to locate it. I need to know how to access the "Privacy Separator"?
What is telling you that you need to disable "the privacy seperator"?
- brooklyngyalAspirant
The problem I'm having is, my devices (laptop/phone) are no longer able to "communicate" with my printer. My printer is "WiFi" and set up as "WiFi".
In troubleshooting why my printer is not comminicating with my devices (laptop/phone) an error message popped up saying to check my "privacy separator and disable it". Thank you in advance :)
What printer do you have?
Is the guest network enabled on the router and is the printer connected to it?
Is your network on the pc/laptops set to private or public?
