johnwho
Oct 24, 2023Star
RAX80 How to disable Wi-Fi Schedule
RAX80 Firmware Version V1.0.10.140_1.0.79 GUI Language Version V1.0.10.140_2.1.46.1 Hello, my router turns off the Wi-Fi every night at 2300 and back on at 0530, as though a schedule is set, but...
Oct 24, 2023Guru - Experienced User
Is there a check box that you can remove to disable it on the routers web page?
