BGJ0912
Oct 01, 2020Follower
RAX80 HP Printer Problem
I have had the Nighthawk RAX80 router for about 10 months and it has worked great. I recently added an HP printer (HP OfficeJet Pro 9010 series) to the Network and have had nothing but trouble. ...
yamaha33166
Oct 05, 2020Aspirant
Hello. I was having the same issue with two different wireless printers.
The printers would connect via WIFI with no issues and they would have an IP address assigned.
I would be unable to ping the IP addresses and therefore unable to print.
After chatting with support, they adviced me to change the 2.4GHz and 5GHz configuration from AUTO to the highest channel.
That has cleared up the issue for me.
I thought AUTO would have worked best since it is supposed to scan for busy channels but that does not seem to be the case.
Hope that helps.
- jcaxOct 05, 2020Star
I'm in a total Windows environment, but also had some trouble with getting HP printer (ENVY Photo 7800) reliably connecting to my RAX80 and devices being able to print.
Confirguration that solved it for me was to only connect the printer to my 2.4GHz SSID, and to remove credentials for my 5GHz SSID. I'm guessing this is similar end result to what yamaha33166 suggested.
Prior to making that change, a power-off/power-on recycle of the printer would temporarily clear things up.
Cheers!
