Jacky912
Oct 03, 2020Initiate
RAX80 intermittent disconnect of LAN
Hi all, I am a RAX80 user since Jan 2020, kept encounter intermittent LAN disconnection under different version of firmware. The retailer replaced the device a few months ago but issue still persis...
patkee
Oct 03, 2020Aspirant
I also use RAX80 (AX6000). I was able to use at the patio throughout summer but this past month, I still have good signal but the wifi signal will drop or disconnect occasionally before coming back again. Is this the same thing that you have? I'd love to know if you find a solution. Thanks.
- Jacky912Oct 05, 2020Initiate
I am not sure if the Wi-Fi also affected. It is hard to tell if it reconnect within a few seconds.
- GabboCHNov 17, 2020ApprenticeSearch the other RAX80 threads in the forum.
LAN disconnect is a common problem, I have it on mine.
There are also many issues with Wi-Fi connection, Smart Connect & overall throughput.
No support or feedback from Netgear.
Only solution is you return it and buy something else.
