Jacky912
Oct 03, 2020Initiate
RAX80 intermittent disconnect of LAN
Hi all, I am a RAX80 user since Jan 2020, kept encounter intermittent LAN disconnection under different version of firmware. The retailer replaced the device a few months ago but issue still persis...
Jacky912
Oct 05, 2020Initiate
I am not sure if the Wi-Fi also affected. It is hard to tell if it reconnect within a few seconds.
GabboCH
Nov 17, 2020Apprentice
Search the other RAX80 threads in the forum.
LAN disconnect is a common problem, I have it on mine.
There are also many issues with Wi-Fi connection, Smart Connect & overall throughput.
No support or feedback from Netgear.
Only solution is you return it and buy something else.
