JJ77
Jul 06, 2019Tutor
RAX80 ip cam Poe cannot connect
POE ip cam set up on static Ip is not recognized and shows red on router
1 Reply
- Christian_RNETGEAR Employee Retired
Hello JJ77 - If you recently purchased the router, you may activate your complimentary support to get in contact with our Support Team using the link below.
https://www.netgear.com/support/default.aspx
~Christian
