Deadaus
Jul 05, 2021Tutor
RAX80 IPv6 drops after an hour with Rogers
Hi, I have the latest firmware - V1.0.4.120_1.0.61 and have reset router once installed. Tried this persons fix since I had the same modem from Rogers with similiar issue: https://community.n...
Jul 06, 2021Guru - Experienced User
And what actual modem/gateway do you have?
the thread/user stated that all of the hiltron devices had that issues when in bridge mode.
Maybe its an issue specific to how your isp is provisioning their gateways for bridge mode.
Have you tried leaving the modem/gateway in modem/router mode , disable its wifi, and then put the netgear in access point mode?
Or leaving the modem/router in router mode (disable its wifi) and putting the netgears IP address into the modem/router's DMZ?
Deadaus
Jul 07, 2021Tutor
Thanks for the reply.
I acutally tried once again a full reset and set-up and I am glade to say it is keeping the ipv6 address now. So it looks like it was related to the older modem from Rogers that was the issue.
Cheers.
