RoadKingMoe
Dec 25, 2019Aspirant
RAX80 IPv6 ICMP Filter Option
Firmware: V1.0.1.70_1.0.30
GUI Language: V1.0.1.70_2.1.46.1
The very first time I set up this router, yesterday, there was a setting for IPv6 ICMP filtering that had 3 options; none, UDP only, and UDP and TCP. This didn't match the ICMP option listed in the User Manual. I wasn't thinking and set it to the latter.
Now that I want to disable it, that option doesn't show up anywhere I can find. I've even done a factory reset and that didn't help.
How can I find it/get it back?
Thanks!
1 Reply
- RoadKingMoeAspirant
One other thing that's changed since the first setup...
ADVANCED -> Setup -> WAN Setup -> Respond to Ping on Internet Port
was initially unchecked. Once I checked it, it no longer responds to a mouse click to uncheck it.
Perhaps this is related to not seeing the IPv6 ICMP Filter choice anymore?
At any rate, I found a here post detailing the option in debug.htm and enabled it, which allows the IPv6 test sites to pass the filter check.
