kentlawrence67
Aug 19, 2020Tutor
RAX80 is supposed to be backward compatible with other 802.11 (b/g/n) standards, but isn't
I have a two laptops running Windows 10 and Windows 7 with two different wireless LANs that can't see the SSID of my RAX80 router. The SSID is broadcasting and I have multiple devices throughout my ...
Christian_R
Aug 25, 2020NETGEAR Employee Retired
Hello kentlawrence67,
Welcome to the community! Have you had a moment to get in contact with our support team regarding your concerns?
https://www.netgear.com/support/default.aspx
Christian
kentlawrence67
Aug 25, 2020Tutor
Nope. Netgear cuts you off after 90 days unless you pay exorbitant support fees. No thanks. I just access those computers using a wifi hotspot from my phone, which is backward compatible and does work.
