user1234234
Aug 03, 2020Follower
RAX80 keeps disconnecting
My RAX80 keeps disconnecting from devices, wifi and wired. But Remote Management still works through the Nighthawk app via mobile data connection. I have the lastest firmware update. Any ideas? This has been the most frustrating router I have ever owned and I have gotten 0 support from netgear this far. Really frustrating trying to find a solution for this.
1 Reply
Which version of the firmware are you on?
What modem are you conencted to?
Have you tried a simple factory reset and manual reinstall? The RAX devices are the newest of the new and got many firmware changes during updates. this has caused them to respond favorably to resets.
