Manazir
May 31, 2020Guide
RAX80 keeps droping internet connection randomly
Hi I am using Netgear Nighthawk AX8 router for a month now. I am noticing that the router drops internet connection randomly and does not reconnect until I reboot the router. I am having this issue...
Manazir
May 31, 2020Guide
Yes. I have done a factory reset after the update and then configured the router manually. I do not seem to understand why this is repeating. Also this mostly happens during late night/early morning. plemans
May 31, 2020Guru - Experienced User
what gateway is it connected to?
- ManazirMay 31, 2020Guide
The router is connected directly to ISP's ethernet line.
- plemansMay 31, 2020Guru - Experienced User
and that ethernet line connects to something. Thats an important piece of information.
What gateway is it?
And who's the isp?
I am from Bangladesh. The ISP is a local one(SB Network). May be my device is connected to on of ISP's switch.
